Hi
Please check that the expected network card is considered as first entry in Registry Editor of the Operating System:
1. Open Windows registry editor by running “regedit” from a command prompt or the Windows "Run" menu with administrator privileges (Run DOS command).
2. Expand the following key “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkCards”
3. This key will contain numbered folders corresponding to all the network cards installed on the machine
4. Locate the desired folder by matching the "Description" field in the Registry Editor to the "Description" line from “ipconfig /all” for the desired network card
5. Rename this folder to "1"
6. Go to File > Exit to close the registry editor
Also, uncheck "Allow the computer to turn off this device to save power" option for the Ethernet Adapter LAN
1. Go to Device Manager > Network Adapters
2. Select the network card used to generate the license file and go to Properties
3. Select Power Management tab and uncheck the option "Allow the computer to turn off this device to save power
This should help to resolve the issue
Vipul
