18-Opal
I want to create a variable with number in front
HI
How can I make a variable  like
3Io:=75A
I don't want `3Io  or ~3Io    .3Io
LucMeekesAnswer
23-Emerald V
Done
Attached is the Prime 3.1 file.
The same trick works in Prime 4.
ctrl+shift+k
space
ctrl+shift+k
18-Opal
Does not work for Prime 4.0 - ok for mathcad 15
It's possible to use special characters in variables by first putting them in quotes, then deleting the quotes.  However, I don't think this trick works to get a variable starting with a number.  I just tried in P3.1 and it didn't work.  Perhaps P4.0, but I doubt it.
18-Opal
No it  does not work unfortunately.
The following special characters look like 3's and are accepted as the first character of a variable (quotes trick needed): З Ӡ Ʒ ʒ
I'm sure it's not what you were looking for, but the best work-around I could find.
LucMeekes23-Emerald VAnswer
23-Emerald V
Done
One old Mathcad 15 joke:
