Indexing again
Hello To All,
A few of you were really helpful in pinning down my indexing problem. In the attached is part of what I have been working on in the background. Please do not get too hung up on what the overall picture is or anything until the end of the sheet, you will see that I have created a couple of tables toward the end of values and have integrated between two sets of values (column 1 of each table with matrix Z(I) to get some areas and then have integrated these areas to get a volume. I now want to do this in terms of j I.e. get 5 volumes to account for each column of the tables. Any ideas where I am going wrong?
Andy.
23-Emerald I
You create a 2D array b, then try to address it as a single dimension vector:
If you do the interpolation against the whole column "cntrl-shift-c", things work better:
awibroe1-VisitorAuthor
PS I am using MCPrime 3
23-Emerald I
Many Thanks Fred!
So as each is a column in the b matrix that makes allot of sense!
23-Emerald I
You must have an integer for an array index phi = ??
