Integrating an Array
Does Mathcad have any function to integrate an array without doing a polyfit? If you see attached, I have a 14 point array and would like to find the area under the curve. What would be the best and cleanest way to accomplish this?
(Note: I had to attach a picture because it wasn't letting me attach a mathcad file for some reason)
23-Emerald I
March 8, 2018
In addition to polyfit (which does a least squares approximation for the order you specify) there are a host of spline fits that will hit the points exactly.  For your data that is probably a better fit to get an integratable function.  Note that since your function is both positive and negative the "area under the curve" will require careful definition.
For a quick and dirty answer linterp will draw straight lines from point to point and can be integrated.
23-Emerald I
March 8, 2018
23-Emerald I
March 8, 2018
examples
dmayfield1-VisitorAuthor
EXTREMELY helpful. Thank you very much
23-Emerald V
March 8, 2018
A serious bug in this forum often prevents from attaching a mathcad file. In Windows Explorer click with the right-mouse button on the mathcad file and select 'Send to' -> 'Compressed (zipped) folder'. The resulting .zip file can be attached.
As you can see, that's what Fred did to attach his file...
Success! Luc
