Werner_EAnswer
Please state which version of the program you are using. Real Mathcad (Version 15 and below) or Prime.
What exactly you are referring to with "table"? Primes table which is only a not very useful way to define vectors or a Mathcad matrix.
Obviously you are used to do calculations in Excel but you have to keep in mind that Mathcad is a much more powerful math program. So stop thinking of cells, columns and tables and start thinking in mathematical functions because this is it when one variable depends on another.
It would be helpful if you could provide a specific simplified example of what you are trying to do.
Would this help:
Werner_E25-Diamond IAnswer
Would this help:
Utilizo Mathcad Prime, la consulta iba en el sentido de que la columna N60 pueda generar resultados automáticamente ya que como se puede apreciar depende de la columna Nspt.
Tiene toda la razón, la costumbre de utilizar siempre Excel no hace confundir las cosas.
La consulta era para ver si es que es posible lo explicado anteriormente.
Muchas gracias
23-Emerald I
Mathcad is not EXCEL
