How to Calculate Gain and Phase
I have a question.
I want calculate Gain and Phase.
But I can not calculate Gain. Phase is OK.
??? I want to attach MATHCAD file. But I do not know how do I attach the file the message.
Please advise me.
Werner_EAnswer
Here is your first file "repaired" using vectorization and made some changes with s (similar to waht you did in your last file)
18-Opal
 Use "Choose File" button to load a file or use photo to load pictures.
By me it does not work!
> If possible I want to know this difference.
 You mean why your first file failed and your current file question_3 works OK?
This is mainly because in your older file f was a vector, not a range as it is in the new file.
vectors and ranges are quite different and often are mixed up.
I try to attach two articles which Stuart created quite a while ago.
To make the old file work you would have to vectorize the call GPA(f).
There also are some differences in the definition and use of function/argument s in the two files.
ssato15-MoonstoneAuthor
Thank you so much for everyone.
I have another trouble.
A few days late , I will return to here, and reply your answer.
Maybe it would be a good idea to open a new thread for your new question.
