May 4, 2015 8:53 PM UTC
Mathcad15 - Help with Functions
Hi - I'm not sure if I am doing this correctly - my question I am working on is :
So I know that x(t) = 1 when t=0, and V(t)=5 when t=0, so I use x(t)=1 on the 1st Equation and Solve for B so I get B=1-A
then I substitute 1-A for B in equation 2, set v(t) equal to 5 and t=0, Solve for A ......
However I'm not getting the correct answers so don't know what I'm doing wrong - can anyone help me on this one please ?
thank you
May 4, 2015 10:11 PM UTC
Pleas post a worksheet showing what you have done (click on "Use advanced editor" at the top right of the edit dialog).
ccoldham1-VisitorAuthor
May 5, 2015 4:45 PM UTC
Ok I will do this this evening - thank you
May 5, 2015 10:47 PM UTC
My replies are not the same as yours ! Quite strange - so I don't get that same reply screen as you .
23-Emerald I
May 5, 2015 7:28 PM UTC
To input a complex number, say 5 + 3 j, you have to type the following:
5 + 3 * 1j
The 1j (or 1i) is typed with no multiplier; this tells Mathcad that you're inputting an imaginary number.
