Aug 17, 2011 3:13 PM UTC
Matlab data to Mathcad
Hi guys. I have an important question. I have a my full program of OFDM and a laser to modulate it in Matlab. its optical communication.
Now I have a solid complicated nonlinear Schrodinger equation that defines my optical fibre. To program it in matlab, it might take ages. Cause it concerns partial derivative and so on.
so I thought may be I can write that equation in Mathcad, and get the data across the laser to Mathcad. Do the math and get the values back to Matlab.
Is that possible?
thank you. If you have any suggestion on this or perhaps any tutorial, please share it with me. Thank you very much!
VladimirNAnswer
Aug 18, 2011 6:56 AM UTC
Hello!
You can find a link to the guide "Developer's Reference" in "Mathcad Help" (F1 key):
Or use the direct link: C:\Program Files\Mathcad\Mathcad 15\doc\HELP_EN\DevRef\DevRef.htm
Developer
P.S. Also look in the Help topic "MATLAB Component". Quote: "In addition to importing and exporting MATLAB data files using the File Input, File Output, or Data Table components, you can also use the MATLAB component to execute MATLAB scripts using data from your Mathcad worksheet, and return the results to Mathcad."
Aug 17, 2011 5:24 PM UTC
Is that possible?
Yes. You need to call Mathcad from Matlab using the automation interface. See the Developers Reference under the help menu.
OpticGuy1-VisitorAuthor
Aug 17, 2011 5:27 PM UTC
Hi Richard. Thanks for your reply. Where can I find this developers reference? Please advice. Thank you.
Aug 19, 2011 9:49 AM UTC
Richard prompted me: This is from an internal newsletter I wrote a while back
I tried to paste it (the content via cut & paste) in but it won't let me! so see the attachments.
http://collab.mathsoft.com/~Mathcad2000 has all the details - search for 'philip matlab' between 1 oct 2006 and 1 oct 2007 for some other threads
