Newbie problem solving system of 3 ODE's
I was able (with some help from the community 🙂 to solve a single ODE using a MathCAD 5.0 Solve Block but now I want to solve a system of 3 ODE's but I am getting an error (see attached file).
I suspect I am making some newbie error. If someone can enlighten me as to what that error is and tell me how to do the calculation correctly, it would be much appreciated.
TIA,
--Doug
Werner_EAnswer
The problem is the equation for px'(t).
If you replace a for something dimensionless it works.
If k1 has the unit L^2/(min*mol^2) it works.
So something with that equation seems to be wrong.
You have to apply units, even if the value is zero.
So to be on the save side you should write px'(0 s)=...
But you have a unit problem/mismatch in your equations:
You have an expression (1-px(t)) which means px(t) is dimensionless!
So your equation MeOH'(t)=-px'(t) meanst that MeOH(t) must be dimensionless, too.
But one of your IC says MeOH(0 s)=a*rx and this would mean unit mol/Litre which is NOT dimensionless.
So that's a discrepancy.
Maybe the "1" in (1-px(t)) is not unitless? But then there would be other discrepancies, I think.
OK, I found another error which caused the "unknown error" you experience. You typed a capital "P" instead of a lower case "p" as argument of odesolve.
The solve block still fails as of the aforementioned unit mismatches.
I tried your solveblock without any units at all and it works OK.
Here is a pic showing the content of Dougs latest worksheet (with some regions rearranged for compactness):
