20-Turquoise
October 25, 2018
Plotting local max-min-points ?
  Hello Everyone.
           Thanks in advance.
Werner_EAnswer
@lvl107 wrote:
Could you attach *.xmcd ? ( I'm afraid I may hit wrong key stroke... )
    Best Regards.
Hmm, really!??
Here's a slightly different approach:
Unfortunately the more direct and logical
does not work in Mathcad - muPad is not capable to find the solutions.
Set a function that is the derivative of f(x).
Use the root function on this derivative within a range to determine unique roots.
You now have enough info to plot the points.
lvl10720-TurquoiseAuthor
20-Turquoise
October 25, 2018
Many thanks both of you, Valery.Smiley HappySmiley HappySmiley Happy And I still have a query : "How to prove what point is local min-point ?
Best Regards.
In case of this function Mathcads symbolics is capable enough to give you al solutions, so you should use it.
If your goal is to limit the results to x1<x<x2 you may use the "assume" modifier.
