error" An unhandled exception occurred on the dispatcher thread"
  • December 16, 2020
  • 4408 views
I have installed the software successfully but cannot run it. As soon I open the program, I get an error" An unhandled exception occurred on the dispatcher thread"
    There's a file named:
    "MathcadPrime.exe.Config"
    On the path
    C:\ProgramData\PTC\Mathcad Prime
    Delete it, or rename it if you're unsure, and then start Prime again.
    Prime will recreate the file.
    Hi There,
    HI Luc, @LucMeekes
    I have tried the following fix which was suggested earlier but that only allowed me to enter the license information.
    """""""There's a file named:
    On the path
    When I open Mathcad prime 6.0 still comes with same error. I have also attached a log file as well
    I am  assuming that this is not compatible with Window 10 2004.
    Prime 6 sure runs without problems on (m)any Windows 10 system:
    Are you sure you deleted the "MathcadPrime.exe.Config" file?
    If this still fails, then you may need help from PTC support ...like @VipulT .
