7-Bedrock
July 19, 2019
Adding dimension while drawing
  • July 19, 2019
  • 1966 views
Is it possible to type the dimension f.e. on a circle while im drawing it?
Because in Creo 1.0 it was possible when i clicked on the symbol and set the dimension to e.g. "60" it changed it and i could place it on the center for example.
Best answer by Mahesh_Sharma
@ClemensNader
When sketching circle weak dimension will appear after placing circle which can modify at any point in time and it was same in previous versions as well. But when sketching Circle in drawing, it will allow to define the radius when creating circle.
Mahesh_Sharma
22-Sapphire I
July 19, 2019
@ClemensNader
So, there's really no way to type in a length or diameter/radius while I'm drawing a line or a circle? Feels like that should be an easy setting to turn on.
