Jan 7, 2015 3:17 PM UTC
Creo 2.0 - Open a drawing from active part?
Has anybody managed some sort of shortcut/mapkey for this yet? I'm taking about quickly opening a drawing of same name when the model is on screen, the way you can open a model by right clicking in the drawings model tree . .
Jan 7, 2015 4:02 PM UTC
Daryl,
my script was tested in D:\PTC\Open_Model_Drawing_AutoIt directory, if it is possible, create the same path on your disk. If you decide to use different path, then you have to change the path inside my macro.
  1. save open_drawing_cr2.exe into D:\PTC\Open_Model_Drawing_AutoIt
  2. open my config.pro and copy the line into your config.pro (you can see the above mentioned path inside the mapkey)
  3. restart Creo 2.0
  4. open part
  5. typ dd to run my macro
Martin Hanak
Jan 7, 2015 3:46 PM UTC
Daryl,
some time ago I created AutoIt script with requested functionality. It can be used in English version of Creo Parametric 2.0.
This script works when you follow these rules:
  1. model name = drawing name
  2. drawing file is saved in current working directory -OR- in the directory specified in SEARCH_PATH option
If you are in the same "situation", then I can upload my script.
Martin Hanak
dhanley1-VisitorAuthor
Jan 7, 2015 3:49 PM UTC
That would be great, yes!
Oh and what would I do with an AutoIt file?
Daryl,
  3. restart Creo 2.0
  4. open part
Martin Hanak
Jun 12, 2017 12:28 PM UTC
I have a question for this ? Can I use it with Windchill 10.2 ?
I understand that it work with local or network drives, but we would like to use it on Windchill workspace.
Can we do it ?
Sandor Papik
6-Contributor
Apr 30, 2026 2:44 AM UTC
It stopped working in Creo 12. Any advice?
Michael
May 2, 2026 7:36 PM UTC
Creo 12 removed capability of on demand mapkeys. If this app used that then it won’t work anymore. I’ve suggested to PTC to add such a button in Creo as it is often requested and would be somewhat easy to implement.
Michael Bourque
3-Newcomer
May 26, 2026 12:08 AM UTC
! ** drw open **
mapkey oo @MAPKEY_NAMEOpen drawing with same name as active model or selected assembly part;\
mapkey(continued) @MAPKEY_LABELOpen Drawing w/ Same Name (odrw);\
mapkey(continued) ~ Command `ProCmdOpenModel@PopupMenuGraphicWinStack`;\
mapkey(continued) ~ Activate `open_instance` `open`;\
mapkey(continued) %>storetmpfile;%>partnameopen;%>loadconf;\
mapkey(continued) ~ Command `ProCmdModelOpen`;\
mapkey(continued) ~ Activate `file_open` `workspace_pb`;\
mapkey(continued) %partnameopen;\
mapkey(continued) ~ Activate `file_open` `Inputname`;
mapkey ndrw @MAPKEY_LABELNew Drawing w/ Same Name (ndrw);\
mapkey(continued) %>storetmpfile;%>partnamenew;%>loadconf;\
mapkey(continued) ~ Command `ProCmdModelNew`;\
mapkey(continued) ~ Select `new` `Type` 1 `Drawing`;\
mapkey(continued) ~ Activate `new` `chk_use_default_template`0 ;\
mapkey(continued) %partnamenew;\
mapkey(continued) @MANUAL_PAUSEName drawing and Resume.;\
mapkey(continued) ~ Activate `new` `OK`;\
mapkey(continued) ~ Select `dwg_create` `rad_format` 1 `1`;
mapkey >storetmpfile @MAPKEY_LABELStore model name to temp file;\
mapkey(continued) ~ Command `ProCmdModelSaveAs` ;\
mapkey(continued) #CURRENT VALS;\
mapkey(continued) ~ Activate `storage_conflicts` `Close_PushButton`;\
mapkey(continued) ~ Select `file_saveas` `type_option` 1 `db_129`;\
mapkey(continued) ~ Activate `file_saveas` `check_is_secondary` 0;\
mapkey(continued) ~ Activate `file_saveas` `Current Dir`;\
mapkey(continued) ~ Activate `file_saveas` `OK`;\
mapkey(continued) ~ Activate `UI Message Dialog` `ok`;
mapkey >partnameopen @MAPKEY_LABELGets partname to open drawing;\
mapkey(continued) @SYSTEMdel sw.pro\n\
mapkey(continued) dir /b *.pic>\%temp\%\\filename.txt\n\
mapkey(continued) set /p VAR1=<\%temp\%\\filename.txt\n\
mapkey(continued) del \%temp\%\\filename.txt\n\
mapkey(continued) set FILENAME=\%VAR1:\~0,-4\%\n\
mapkey(continued) echo mapkey partnameopen \~ Update `file_open` \
mapkey(continued) `Inputname` `\%FILENAME\%.drw`\;>>sw.pro\n\
mapkey(continued) del *.pic;
mapkey >partnamenew @MAPKEY_LABELGets partname for new part;\
mapkey(continued) echo mapkey partnamenew \~ Input `new` \
mapkey(continued) `InputPanel1` `\%FILENAME\%`\;>>sw.pro\n\
mapkey >loadconf @MAPKEY_LABELLoad mapkey into session;\
mapkey(continued) ~ Command `ProCmdRibbonOptionsDlg`;\
mapkey(continued) ~ Select `ribbon_options_dialog` `PageSwitcherPageList` 1 `ConfigLayout`;\
mapkey(continued) ~ Activate `ribbon_options_dialog` `ConfigLayout.Open`;\
mapkey(continued) ~ Activate `file_open` `Current Dir`;\
mapkey(continued) ~ Update `file_open` `Inputname` `sw.pro`;\
mapkey(continued) ~ Command `ProFileSelPushOpen@context_dlg_open_cmd`;\
mapkey(continued) ~ Activate `ribbon_options_dialog` `OkPshBtn`;\
mapkey(continued) ~ Activate `UITools Msg Dialog Future` `no`;\
mapkey(continued) @SYSTEMDel sw.pro;
