Fatal Error encountered while working in Creo 5.0 Parametric
     While working on Creo 5.0 Parametric Part modeling Experience Fatal Error warning pops up and the program closes, A Traceback file is generated, Screenshot attached. Please suggest a solution.
@Vue412 wrote:
      Where can I find the config.pro,  I tried searching in PTC file in C drive there is multiple config.pro files.
Creo reads config.pro file located in Creo5_LOADPOINT\Creo 5.0.x.0\Common Files\text directory.
In my installation it is E:\PTC\Creo5_050\Creo 5.0.5.0\Common Files\text\config.pro file.
1.] can you reproduce the problem using the same procedure ?
2.] sometimes the problem is related to graphic card drivers
  • open config.pro in Notepad
  • add following option at the end of the file ... graphics win32_gdi
  • test working with Creo
Vue4121-VisitorAuthor
Mahesh_Sharma
22-Sapphire I
@Vue412
Can you share generated traceback file to review?
@Mahesh_Sharma, Please find the attached traceback file
Mahesh_Sharma
22-Sapphire I
@Vue412
There are some threads about graphics ...
Try adding below config options ..
enable_opengl_shader no
enable_opengl_fbo no
enable_opengl_vbo no
Also update the Creo 5.0 datecode to latest available one.
