Nov 6, 2019 8:26 PM UTC
Problem with saving as JPEG
Hello everyone,
today i discovered a little problem. When i tried to save a part to JPEG file, it apeared that it has purple gradient in the picture even though i have my background set to pure white color. I have also discovered that it only appear when i set my resolution to anything higher that 100 DPI, everything higher what 100 DPI will include the gradient colors in the picture.
Thanks in advance.
Nov 7, 2019 8:58 AM UTC
try adding following option into config.pro
graphics   win32_gdi
Nov 6, 2019 8:50 PM UTC
What version and build of Creo?
I did a 600dpi jpeg with white background in Creo4 M080 and it came out fine.
When was the last time you rebooted your workstation?
llibovič1-VisitorAuthor
Nov 6, 2019 9:00 PM UTC
Im using Creo 3.0 version M040. Im working on a laptop. i dont understand why is this happening. I have checked all the settings i have nothing set to purple, at least i think.
StephenW
Nov 6, 2019 9:12 PM UTC
Are you using some sort of render? The purple looks like the top of a "room wall" since it cuts off below the part and there is a "room" that has a purplish hue
