Trace sketch image problem
  • January 5, 2020
  • 6563 views
I'm trying to trace an image in creo. But when I import the image, the image appears to be in this distorted patterned layout. The right image is what I want to import. Does anyone know what's wrong?
Image is in PNG
Best answer by Mahesh_Sharma
@nwb10
ok, with this option slight delay is expected...  in that case you may need to check the machine details at https://support.ptc.com/partners/hardware/current/support.htm
Possibly this is not a supported graphics card to work with Creo.
You may try below options, instead of earlier one.. if that helps.
 enable_opengl_fbo no
enable_opengl_vbo no
enable_opengl_shader no
Mahesh_Sharma
22-Sapphire I
January 6, 2020
@nwb10
Image attached to post is working for me correctly.. possibly a graphics issue. Try setting config option graphics as win32_gdi
nwb101-VisitorAuthor
That solved the problem! However, I also noticed some lag.
I did some searching and apparently win32_gdi does not use graphics card? I'm running a GTX1050 and it is up to date, do you happen to know which settings I can tweak to resolve the issue? Currently all settings are at default.
Mahesh_Sharma
22-Sapphire I
January 6, 2020
@nwb10
