Mar 29, 2018 4:06 PM UTC
3D object looping rotation on button press
Is there a simple way to make a 3d object rotate constantly on a button click?
tmccombieAnswer
Mar 29, 2018 7:26 PM UTC
Using an app parameter and some JavaScript you can achieve this.
Step 1: Depending on which axis you want to rotate the model on, create a new app parameter and bind it to the corresponding rotation property of your model.
I created an app parameter 'ry' and bound it to the y rotation property
Step 2: Add a JS function for the rotation to Home.js
I used the below function - the quadcopter example experience has some additional code examples for moving model parts.
var timerId = -1;
var angleIncrement = 45; // degrees
var timingInterval = 30; // milliseconds
$scope.rotateModel = function(){
 if (timerId > -1) {
 clearInterval(timerId);
 timerId = setInterval(function() {
 	if (!$scope.app.params.ry) {
 $scope.app.params.ry = 0;
 $scope.$apply(function(){
	$scope.app.params.ry += angleIncrement % 360;
 }, timingInterval);
Step 3: Create a button and call the JS function on the Click event
The model will now rotate around the y axis after clicking on the button.
tmccombie21-Topaz IAnswer
var timerId = -1;
 if (timerId > -1) {
 }, timingInterval);
Mar 29, 2018 7:29 PM UTC
Excellent, thank you!  I'll give that a shot.
Apr 4, 2018 12:48 PM UTC
@jsimpsonJD If this worked, please mark the appropriate post with "Accept as Solution" for the benefit of others who may have the same question.
