Mar 21, 2019 12:18 PM UTC
Vuforia View crashes ob Hololens
I created an experience on Vuforia Studio using model target detection and it the detection works fine. That I give more information in the experience, so more pictures and models and now when I start the experience on the Hololens the App is crashing, sometimes just a few seconds after start and sometimes while detection. I tried to split the experience in two parts, and so both work fine. But together not. Maybe the project is to big? Is there an limit on project size for Hololens? I also reconigze that my project can't get bigger than 5 Mbit when i save. I also tried using a Vumark detection instead of the model target detection. But get the same problem. I'm using an test experience service. I also checked if the problem is the internet, but it seems fast enough.
Hope someone can help me
Mar 21, 2019 6:24 PM UTC
Hi @Milliau,
5 MB (project size) should not lead to a problem . I saw projects which are  > 20 MB size and are working fine.
What is the  version of the HoloLens viewer?  I think there is issue with the latest Vuforia View 8.4.1 with textures. Do you have textures in your 3d  model?
Milliau1-VisitorAuthor
Mar 21, 2019 7:19 PM UTC
I updated the Vuforia View, because I thought that this can solve to problem. But doesn't help. No there is no textures in the model. I also tried it without the model and get the same problem.
Mar 26, 2019 11:40 AM UTC
I found a Log on the Hololens and there are this errors:
2019-03-26T12:08:47.864+01:00 [Error] MainPage - Navigating Starting for [null]
2019-03-26T12:08:47.864+01:00 [Error] MainPage - Clearing the ms-local-stream resolver.
But how can i solve them?
