Dale_Rosema
Config.pro option to change color of export to DWG's
  • August 31, 2018
  • 2 replies
  • 28091 views
Last year I added a config.pro option below which allowed .dwg file to be black & white (WF5).
intf2d_out_dxf_mapping_file   (Directory path to dxf_export.pro)
We are now switching to Creo 4.0 and it is back to the color of the drawing on the screen (Yellow with white [black on the scree] background. Very hard to see on a file viewer.
I could not find that config option while searching Creo 4.0 options. Does anyone have a suggestion for another one?
Thanks, Dale
Best answer by Dale_Rosema
I found my error - instead of directory path to dxf_export.pro is needs to be directory_path/folder/subfolder/dxf_export.pro
Since I had forgot to add the filename to the end of the path, it wasn't finding the file.
** So confusing as to when to point to the directory and when to point to the file  🙂
Thanks Martin for all you help in this!
I found INTF2D_OUT_DXF_MAPPING_FILE option in E:\PTC\Creo4_M060\Creo 4.0\M060\Common Files\text\config.cdb file. It seems to me that the option must work. Maybe you have to add it manually into config.pro.
Dale_Rosema
I had added it to the manually to the config.pro. Do you know what file it is looking for? I have a file: "dxf_export.pro" that looks like a pen table with all values set at "7".
let me explain following line extracted from E:\PTC\Creo4_M060\Creo 4.0\M060\Common Files\text\intf_configs\dxf_export.pro
map_color       GEOMETRY_COLOR            7
This line tells that visible geometry edges (GEOMETRY_COLOR in Creo) will get Autocad color no. 7 (white) in DWG/DXF.
You can see Autocad color numbers on web page http://sub-atomic.com/~moses/acadcolors.html.
I guess that in dxf_export.pro you can also use color names (eg. yellow, white, ...) or RGB values instead of numbers.
map_color       GEOMETRY_COLOR            White
map_color       GEOMETRY_COLOR            255,255,255
Therefore the above lines have the same meaning.
Dale_Rosema
Dale_Rosema23-Emerald IIIAuthorAnswer
