Creo on Linux: best practice
  • July 15, 2024
  • 6 replies
  • 9368 views
Hi there,
is there anyone, who managed to run Creo Parametric on a Linux machine?
I was able to start the installation in "wine", but it always has problems installing the "Platform Agent".
KenFarley
In the past I attempted to "wine", not for a Linux machine, but for OS X (a Unix based OS, too), though not Linux. I also tried to install Creo within a Virtual Machine. Never got it to work. I suspect that even if I could surmount all the hardware emulation difficulties (graphics, handling all the licensing communications, etc.) it would likely be very clunky.
I did what you might have already done, too, in that I checked on the Wine site as to what they had tested and all that for Creo. Unsurprisingly, the current rating for using Wine to run Creo 9.0 is "Garbage". There's insufficient interest in doing so for enough people to suffer through all the testing they'd need to do to get it to be acceptably functional. If that's even possible.
Mat16-PearlAuthor
Luckily I was able to get Creo 10.0.5.0 running in Mint22 ( within a VM )
Steps to reproduce ( not a complete step-by-step tutorial)
  • Create a VM with VirtualBox
  • Install Mint 22 within the VM
  • Install "PlayOnLinux"
    • "Install a program"
    • "install non listed program"
    • "install a programm in a new virtual drive"
    • name it "creo 10" (e.g.)
    • choose 64bit installation
    • choose "setup.exe" in Creo installation folder
    • During Creo Installation, I skipped the license configuration ( I do not know, if it made a difference)
    • Surprisingly, the installation finished successfully
    • Choose "parametric.exe" within the PlayOnLinux dialogue to create a shortcut for Creo
  • Navigate to Your virtual "c-drive" and the creo installation folder within to edit "parametric.psf" ( change values for license and features )
  • Start Creo from "PlayOnLinux"
When Creo starts, there are a bunch of warnings (e.g. I could not connect Creo to my windchill server because of a self signed certificate), but it runs for now.
Unfortunately, I do not have some "spare hardware" to install Mint22 directly, yet. But in the VM Creo is still some sort of usable.
?!? That sounds too simple. I shall test this in Ubuntu stat.
I mean, you can install Creo without configuring the license server, but then it should just complain about no license when starting it.
Do you have an external license server that you fetched the license from? I.e 7788@localhost or some such?
Also: do you get any 3D acceleration at all?
Friendly,
/M
Chris3
Mat16-PearlAuthor
Thanks, but I already did 🙂
