Mar 13, 2015 5:37 AM UTC
Error : License request failed for feature
Hi there,
I installed creo 3.0 student edition first without using the lisense file. (by skipping it). after that, i installed the license file with the simple entry option. But i'm getting this error. Please help me out.
I've attached a screenshot of this.
Mar 13, 2015 6:57 AM UTC
license information is included in psf-file located in <Creo3_loadpoint>\Creo 3.0\Mxxx\Parametric\bin directory.
To create psf-file you can run reconfigure.exe located in the same directory.
The default file name is parametric.psf. This file contains following lines:
ENV=PTC_D_LICENSE_FILE-=PATH_TO_YOUR_LICENSE_FILE
You have to substitute PATH_TO_YOUR_LICENSE_FILE with real path.
ENV=CREOPMA_FEATURE_NAME=LICENSE_NAME ()
You have to substitute LICENSE_NAME with real name located on INCREMENT line inside the license file.
Martin Hanak
Martin Hanak
Mar 13, 2015 6:59 AM UTC
the complete text of an error message is written in std.out file. Upload it.
Martin Hanak
nprajwal1-VisitorAuthor
Mar 13, 2015 9:46 AM UTC
Hi, I did reconfigure the parametric.psf using reconfigure.exe. The content is as follows..
ENV=PTC_D_LICENSE_FILE-=C:\ProgramData\PTC\Licensing\BK400407EDSTUDENTUNICL_license.dat
ENV=CREO_APP=PMA
ENV=CREOPMA_FEATURE_NAME=CREOPMA_Student3 ()
and i think this is proper. But i couldn't find the std.out file. can you please tell me where to locate it?
Mar 13, 2015 9:51 AM UTC
std.out is create in Start in directory by default (see Properties of Creo shortcut).
You can also use Windows Search to locate std.out.
Martin Hanak
Mar 13, 2015 10:37 AM UTC
Got it.
Files reads as follows
Requesting CREOPMA_Student3 ...
C:\ProgramData\PTC\Licensing\BK400407EDSTUDENTUNICL_license.dat: (-8) Invalid (inconsistent) license key.
Displaying status for license file: C:\ProgramData\PTC\Licensing\BK400407EDSTUDENTUNICL_license.dat
License In Use Free Version Expire Date SCN
CREOPMA_Student3 Uncounted 34.0 12-mar-2016 Student3 Locked to: 84-4B-F5-DB-B2-4D
CREOLAY_Student3 Uncounted 34.0 12-mar-2016 Student3 Locked to: 84-4B-F5-DB-B2-4D
CREODMA_Student3 Uncounted 34.0 12-mar-2016 Student3 Locked to: 84-4B-F5-DB-B2-4D
Mar 13, 2015 10:43 AM UTC
Hey there,
It worked after reconfiguring the application. (not the one which was in the parametric folder). I used the setup file and opted reconfigure option in that. Then i selected all the applications in that list and viola, it worked! Thanks for help.
Sep 14, 2015 5:06 PM UTC
can you explain how you did that because im having the same problem
