Jul 8, 2015 6:14 PM UTC
How to make scroll wheel zoom work in Windows 10 with Creo Parametric
I had a very difficult time finding a solution for this. I opened a call and PTC said Windows 10 wasn't a supported configuration. Fortunately a curious co-worker discovered the fix. Not having zoom with the scroll wheel was a show stopper for me. Here's how to make it work as before:
1. Select the Start button
2. Type "mouse & t" in the search area and press Enter
3. In the Mouse & touchpad settings dialog select the toggle for Scroll inactive windows when I hover over them until it displays Off.
4. Launch Creo Parametric and marvel at mouse wheel zooming
Jul 25, 2015 9:08 PM UTC
Hurray.....!
Thank You
Its Working
Jul 29, 2015 10:00 AM UTC
hi, i did it in windows 10 and it doesnt work... i cant make zoom with the wheel in my windows 10... so i cant use the program. what can i do??
Jul 29, 2015 11:07 AM UTC
temporary, set mapkeys.
I have it for the function keys F2 and F3: Zoom in and out respectively
mapkey zi @MAPKEY_NAMEZoom in;@MAPKEY_LABEL>Zoom in;\
mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdViewZoomIn.view`;
mapkey zo @MAPKEY_NAMEZoom out;@MAPKEY_LABEL>Zoom out;\
mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdViewZoomOut.view`;
mapkey $F2 @MAPKEY_NAMEDefine Zoom box;@MAPKEY_LABEL>Zoom In;%zi;
mapkey $F3 @MAPKEY_NAMEZoom Out;@MAPKEY_LABEL>Zoom Out;%zo;
Jul 31, 2015 12:24 PM UTC
Thank you for your help.
Good working.
Aug 5, 2015 11:43 AM UTC
thank you!!!
Aug 6, 2015 5:16 PM UTC
This worked for me on Windows 10 - many thanks.
Aug 8, 2015 7:02 AM UTC
You are the best in the world !!!!!!!!!!!!!!!!!
I was very disperated but you are my savior !!!!
many many thanks
Aug 11, 2015 6:17 PM UTC
Thank you very much!
2-Explorer
Jul 20, 2018 5:26 PM UTC
I'm having this same problem with my wireless M590 and the above solutions did not work but I have the other culprit to my problem which solved it and though I would share:
If you are having trouble zooming in Creo with mouse wheel go to control panel>hardware sound>mouse and click on the "Wheel" tab and set the option in the vertical scrolling area  "one screen at a time" this solved my problem.
Sep 1, 2020 6:33 PM UTC
Thank you so so much! Worked like a charm! 😁
Aug 13, 2015 4:01 AM UTC
You, sir, are awesome.
Aug 14, 2015 2:04 AM UTC
Aug 14, 2015 7:25 AM UTC
Its Working Thank you very much!
