Active Directory Integration - LDAP or Azure
  • June 22, 2022
  • 1595 views
Hi Folks,
Whether LDAP or Azure AD will be faster to integrate considering minimum configurations on the Thingworx platform end.
Please share if any guide or steps are already there to achieve the same.
Best answer by PaiChung
Please see if you can do it with 'Directory Services' that would be the quickest way I think.
https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Composer/Security/DirectoryServicesAuthentication/DirectoryServicesAuthentication.html#
PaiChung22-Sapphire IAnswer
22-Sapphire I
June 23, 2022
TanmeyTWX17-PeridotAuthor
Yes Pai, I am also thinking to use Directory services- LDAP option only. But need to check the directory system at other end first if a LDAP connection will work or need to have SSO as well. I will post the decision here once done.
Thanks!
