Auto-refresh function not working in a popup
  • February 23, 2021
  • 11 replies
  • 5159 views
I have put a label in a mashup & data for that label is coming from a service. That service is being invoked by an auto-refresh function. It is working as expected when that mashup is run solely. But when I open that mashup from another mashup, using the navigation function, the auto-refresh doesn't seem to work at all.
Best answer by suverma
Hi @SB_9732186
Just found out that the fix for Auto-Refresh not working in a pop-up will be delivered in 9.1.3 too along with 9.2.0.
So if you want you can simply do a patch update to 9.1.3 than upgrading to 9.2.
Hi @SB_9732186
I will try and replicate that. Can you please let me know your Thingworx version.
Thingworx version 9.1
I have a similar use case on ThingWorx 9.1 and auto refresh works fine there with Navigation - New window as well as pop up. I am not sure if this was reproducible on any older version but @suverma can try on your build itself.
Hi @mnarang ,
Can you please attach some screenshots of your setup, which consists of the bindings & other configurations.
Thanks.
I have created a small test for you and attaching all the entities.
Note:- you can observer that autorefresh is working absolutely fine by observing the service call in F12
Support
June 4, 2021
Hi @SB_9732186.
ThingWorx 9.1.3 was delivered last week.  Please check to see if this version resolves your issue.
Regards.
--Sharon
