Blinking LED Display Widget
dmahoney
I have got a LED Display Widget.
When the value is less than 5, I change the color to red.  How can I make the number blink?
Dan
5 REPLIES 5
supandey
(To:dmahoney)
Hi Dan, do you just want to change the color at once the moment the value goes below 5 or you want it to continue blinking the moment values goes below 5. If it's just about changing once you can do that with State Definition
Thanks.
Yep, state definition got me to red digits. Now I would like to add blinking and didn't see any builtin way to do it.
Dan
ankigupta
(To:dmahoney)
Hi Dan Mahoney​,
As per my knowledge; this feature(number blink in LED widget) is not available out of the Box. You may look into widget modification and custom extensibility  to develop your own solution. Attached is documentation/guides.
qngo
(To:dmahoney)
Hi, I think about a workaround. You can place a second empty LED Display widget (2) on the first one (1). When the value of (1) is less than 5, use a Validator to activate an AutoRefresh which changes frequently the Visibility of (2) on (1) (with a service, a Validator widget, a Expression widget...), to make a blink effect.
amittal-3
(To:qngo)
Hello qngo,
I am having the same requirement of blinking LED, and I am trying to implement your solution (workaround), but I am not able to understand it completely. Being a newbie to thingworx platform, I would request you if you can explain your workaround in a little detail in steps.
