Sep 4, 2019 8:37 AM UTC
Calling service API from Postman - 403
Hi. I cannot call a service over Postman/anywhere without 403 access denied.
It works fine from a mashup. Guessing I have the same issue as here: https://community.ptc.com/t5/ThingWorx-Developers/REST-API-test-of-simple-service-returns-HTTP-403/td-p/526341
However the solution there, when I try to do it and save the changes I get: INVALID SCN SET https://i.imgur.com/xCRTLWa.png
"You have to go to System / Subsystems / PlatformSubsystem / Configuration. Check "Allow Request Method Switch" and uncheck "Filter Content-Type"."
What could be the issue? Am I missing something?
raluca_edu
Sep 4, 2019 8:54 AM UTC
Please check this article: https://www.ptc.com/en/support/article?n=CS304668
A workaround is available:
  • Disable Metrics Reporting by deselecting the Metrics Reporting Enabled checkbox
Thank you,
Raluca Edu
raluca_edu
Thank you,
Raluca Edu
