Communications Endpoint Closed i JAVA SDK
  • June 22, 2016
  • 3 replies
  • 4434 views
Hi
I got error, can you please tell me How to solve this problem, when i ran the Java SDK it was showing error like this
12:37:05.724 [main] DEBUG i.n.u.i.l.InternalLoggerFactory - Using SLF4J as the default logging framework
12:37:05.724 [main] DEBUG i.n.c.MultithreadEventLoopGroup - -Dio.netty.eventLoopThreads: 8
12:37:05.740 [main] DEBUG i.n.util.internal.PlatformDependent0 - java.nio.Buffer.address: available
12:37:05.740 [main] DEBUG i.n.util.internal.PlatformDependent0 - sun.misc.Unsafe.theUnsafe: available
12:37:05.740 [main] DEBUG i.n.util.internal.PlatformDependent0 - sun.misc.Unsafe.copyMemory: available
12:37:05.740 [main] DEBUG i.n.util.internal.PlatformDependent0 - java.nio.Bits.unaligned: true
12:37:05.740 [main] DEBUG i.n.util.internal.PlatformDependent - Platform: Windows
12:37:05.740 [main] DEBUG i.n.util.internal.PlatformDependent - Java version: 7
12:37:05.740 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noUnsafe: false
12:37:05.740 [main] DEBUG i.n.util.internal.PlatformDependent - sun.misc.Unsafe: available
12:37:05.740 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noJavassist: false
12:37:05.740 [main] DEBUG i.n.util.internal.PlatformDependent - Javassist: unavailable
12:37:05.740 [main] DEBUG i.n.util.internal.PlatformDependent - You don't have Javassist in your class path or you don't have enough permission to load dynamically generated classes.  Please check the configuration for better performance.
12:37:05.740 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.tmpdir: C:\Users\524708\AppData\Local\Temp (java.io.tmpdir)
12:37:05.740 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.bitMode: 64 (sun.arch.data.model)
12:37:05.740 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noPreferDirect: false
12:37:05.755 [main] DEBUG io.netty.channel.nio.NioEventLoop - -Dio.netty.noKeySetOptimization: false
12:37:05.755 [main] DEBUG io.netty.channel.nio.NioEventLoop - -Dio.netty.selectorAutoRebuildThreshold: 512
12:37:05.771 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.numHeapArenas: 8
12:37:05.771 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.numDirectArenas: 8
12:37:05.771 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.pageSize: 8192
12:37:05.771 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.maxOrder: 11
12:37:05.771 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.chunkSize: 16777216
12:37:05.771 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.tinyCacheSize: 512
12:37:05.771 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.smallCacheSize: 256
12:37:05.771 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.normalCacheSize: 64
12:37:05.771 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.maxCachedBufferCapacity: 32768
12:37:05.771 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.cacheTrimInterval: 8192
12:37:05.771 [main] INFO  c.t.c.c.p.ClientMessageProcessor - Created new ClientMessageProcessor [minPoolSize: 4, maxPoolSize: 10, maxThreadLife: 10000, maxQueueSize: 1000]
12:37:05.787 [main] DEBUG c.t.c.c.e.m.ConnectivityMonitorTask - Initializing CommunicationEndpoint Connection Monitor...
12:37:05.849 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.ConnectivityMonitorTask - Resetting duty cycle
12:37:05.849 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.ConnectivityMonitorTask - Entering duty cycle ON
12:37:05.849 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.m.ConnectivityMonitorTask - Endpoint not connected [name: SteamSensorGateway, id: 0]. Attempting [re]connect...
12:37:05.849 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
12:37:05.849 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
12:37:05.958 [Client-EndpointMonitor-1] DEBUG i.n.util.internal.ThreadLocalRandom - -Dio.netty.initialSeedUniquifier: 0x43ed3595d8f82968 (took 8 ms)
12:37:05.974 [Client-EndpointMonitor-1] DEBUG io.netty.buffer.ByteBufUtil - -Dio.netty.allocator.type: unpooled
12:37:05.974 [Client-EndpointMonitor-1] DEBUG io.netty.buffer.ByteBufUtil - -Dio.netty.threadLocalDirectBufferSize: 65536
12:37:05.989 [NettyClient-NIO-1] DEBUG c.t.c.c.c.n.NettyClientConnectionFactory - initializing a secure websocket connection [ignore ssl errors: true]
12:37:06.223 [NettyClient-NIO-1] DEBUG io.netty.util.ResourceLeakDetector - -Dio.netty.leakDetectionLevel: simple
12:37:06.457 [NettyClient-NIO-1] DEBUG io.netty.util.Recycler - -Dio.netty.recycler.maxCapacity.default: 262144
12:37:06.457 [NettyClient-NIO-1] DEBUG c.t.c.c.c.n.ThingworxClientConnectionHandler - WebSocket Channel is connected [is open: true]
12:37:06.473 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocketClientHandshaker13 - WebSocket version 13 client handshake key: LEVUCD63fTo1R6jRTGK+uw==, expected response: 5vPutxkMO+yRK2zRXwuzpocwDkE=
12:37:06.691 [NettyClient-NIO-1] INFO  c.t.c.c.c.n.NettyClientConnectionFactory - TRUST-ALL X509TrustManager.checkServerTrusted called [issuer: CN=DigiCert SHA2 High Assurance Server CA, OU=www.digicert.com, O=DigiCert Inc, C=US, subject: CN=*.portal.ptc.io, O=PTC Inc., L=Needham, ST=MA, C=US, authType: ECDHE_RSA]
12:37:06.691 [NettyClient-NIO-1] INFO  c.t.c.c.c.n.NettyClientConnectionFactory - TRUST-ALL X509TrustManager.getAcceptedIssuers called
12:37:06.958 [NettyClient-NIO-1] DEBUG io.netty.handler.ssl.SslHandler - [id: 0xad494e38, /10.251.71.7:51887 => pp-20160303165712179.portal.ptc.io/52.5.87.101:443] HANDSHAKEN: TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA
12:37:07.176 [NettyClient-NIO-1] DEBUG c.t.c.c.c.n.ThingworxClientConnectionHandler - [ClientHandler: 2055812419] Client websocket handshake is complete
12:37:07.192 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.ClientCommunicationEndpoint - Preparing new Connection Authentication Request: DispatchingClientEndpoint [id: 0, isConnected: false, open connections: 0, max connections: 1]
12:37:07.192 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.CommunicationEndpoint - Sending connection authentication message, waiting for response [sync key: 1, message: AuthRequestMessage [requestId: 1, endpointId: -1, sessionId: -1, method: AUTHREQUEST]]
12:37:07.192 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=60
12:37:07.410 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=2
12:37:07.410 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame length=17
12:37:07.426 [NettyClient-NIO-1] DEBUG c.t.c.c.e.DispatchingClientEndpoint - RESPONSE received [endpoint id: 0, duration: 234] ResponseMessage [requestId: 1, endpointId: 1488, sessionId: 1488, code: STATUS_SUCCESS, multipart: false, packet #: 0, total packets: 0]
12:37:07.426 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.ClientCommunicationEndpoint - Authentication Request was SUCCESSFUL [tworx session id: 1488, connection group id: 1488]
12:37:07.426 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.CommunicationEndpoint - [Endpoint id: 0, connection id: 0-0] added Connection
12:37:07.426 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.ClientCommunicationEndpoint - Successfully reconnected client endpoint [id: 0] : [active: 1, max: 1]
12:37:07.426 [Client-EndpointMonitor-1] INFO  c.t.c.client.ConnectedThingClient - Communications Endpoint Opened
12:37:07.426 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.CommunicationEndpoint - Sending synchronous message, waiting for response [sync key: 2, message: BindRequestMessage [requestId: 2, method: BINDREQUEST, names: [*SN00010, *SN00011, *SN00012, *SN00013, *SN00014, *SN00015, *SN00016, *SN00017, *SN00018, *SN00019, SteamSensorGateway, SteamSensorGateway]]]
12:37:07.426 [NettyClient-NIO-1] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=176
12:37:07.644 [NettyClient-NIO-1] INFO  c.t.c.c.c.n.NettyClientConnection - [websocket id: 0-0] Closing underlying websocket channel
12:37:07.644 [NettyClient-NIO-1] INFO  c.t.c.c.c.n.NettyClientConnection - [websocket id: 0-0] Unregistering NettyClientConnection from ClientEndpoint
12:37:07.644 [NettyClient-NIO-1] DEBUG c.t.c.c.e.CommunicationEndpoint - [Endpoint id: 0, connection id: 0-0] removed Connection
12:37:07.644 [NettyClient-NIO-1] INFO  c.t.c.c.e.CommunicationEndpoint - All Connections are closed [endpoint id: 0]
12:37:07.644 [NettyClient-NIO-1] INFO  c.t.c.client.ConnectedThingClient - Communications Endpoint Closed
can you pinpoint the error?
dcbb1-VisitorAuthor
Hi
Is there anything in the Platform logs? If possible put the communication log on "trace" and try connecting your SDK application again.
Regards
Ian
dcbb1-VisitorAuthor
Out of curiosity, do you leave the Java SDK running after the INFO message or does it completely kill the application from proceeding any further? Once the websocket closes it should attempt a reconnect once property updates need to be pushed again.
Meghan
