Nov 11, 2025 7:58 PM UTC
Create Mashup URL with Initial Infotable Parameter
Hi all,
I am aware that you can set a mashup parameter using a URL for example:
<<THINGWORX>>/Mashups/TestMashup?thingName=TestThing
However, I have a use case where I would like to preload an infotable property into the URL. Is this possible? And if it is does anyone know the syntax?
nmutterAnswer
Nov 12, 2025 1:04 PM UTC
I tested with urlencoded serialized infotable and it worked
{"dataShape":{"fieldDefinitions":{"description":{"name":"description","description":"Entity description","baseType":"STRING","ordinal":0,"aspects":{}},"name":{"name":"name","description":"Entity name","baseType":"STRING","ordinal":0,"aspects":{"isPrimaryKey":true}}}},"rows":[{"description":"world","name":"Hello"}]}
url encoded:
http://localhost/Thingworx/Runtime/index.html?mashup=Test&entities=%7B%22dataShape%22:%7B%22fieldDefinitions%22:%7B%22description%22:%7B%22name%22:%22description%22,%22description%22:%22Entity%20description%22,%22baseType%22:%22STRING%22,%22ordinal%22:0,%22aspects%22:%7B%7D%7D,%22name%22:%7B%22name%22:%22name%22,%22description%22:%22Entity%20name%22,%22baseType%22:%22STRING%22,%22ordinal%22:0,%22aspects%22:%7B%22isPrimaryKey%22:true%7D%7D%7D%7D,%22rows%22:%5B%7B%22description%22:%22world%22,%22name%22:%22Hello%22%7D%5D%7D
and it did render my grid which bound the entities mashup parameter:
mashup config:
Not sure if there is a more compact way for this. I dont think you can pass too much data to it via url this way...
Maybe you could have some "landing" mashup which would navigate to your target mashup, passing wanted default parameters instead?
nmutter17-PeridotAnswer
url encoded:
mashup config:
Nov 12, 2025 2:11 PM UTC
This did work, but I found for my case it was easier to send query parameters through the URL then call a query of the data in the mashup, rather than trying to push a large infotable of data through the URL.
Jamal Ashraf
Nov 13, 2025 5:31 AM UTC
Hi @JK_10744682  would you please share the steps with which you have achieved desired behaviour so that it would be helpful for the community to easily understand if they have a similar query in the future. Thanks
