Jan 11, 2021 10:19 AM UTC
Creating Multiple User Login in Thingworx
Hi
I am looking create multiple user login and based on user i have to give particular mashup access and how session can be handled for each user ? can we create this using Organization?
Vaibhav
odukiyaAnswer
Jan 11, 2021 5:27 PM UTC
Hello @VS_9760165
Yes. So the TWX server manage the User Sessions by the User name, if you login with different User name, the session will be logged separately, if you login with same User in different machine/ browser, the login will be updated, and probably you'll sign in the latest page.
If it has answered your query please mark the appropriate reply as solution. In case you have further query , please revert.
Om Dukiya
Jan 11, 2021 12:49 PM UTC
Hi @VS_9760165 ,
the multi-user login creates different sessions, the permission for each login only depends on the User you used. So configure the User permissions carefully would grant them different access.
The Organization gives Users 2 rights:
1. Visibility permission to entities
2. FormLogin access to Home Mashup of the Organization.
Om Dukiya
Jan 11, 2021 2:36 PM UTC
Hi @odukiya ,
Please Correct me if i am wrong.  When we assign multiple user while creating organization then only it creates session for each user right?
Jan 11, 2021 6:32 PM UTC
Hello @VS_9760165
I hope this article can help
https://www.ptc.com/en/support/article/CS321910
Om Dukiya
