Apr 23, 2021 7:10 AM UTC
D3 Pie chart with half circle
Is there a way to make d3 pie chart( donut chart) to show only half circle part?
The reference image is given.
yhanAnswer
Apr 23, 2021 9:34 AM UTC
Hi @PM_9712905
The D3 pie chart is not available OOTB. I did some searching and find "Pie Chart to Donut Chart and add boundary to the bar chart" may meet your needs.
You can also refer ThingWorx Extension Development Guide chapter 8 for customized widget implementation.
/Yoyo
Apr 23, 2021 8:27 AM UTC
Hi @PM_9712905,
Currently, there is no D3 Pie Chart Widget in ThingWorx OOTB that can load a half-ring Chart.  You need to customize D3 Pie Chart that has a half-ring feature via js as a ThingWorx extension, then import the extension to TWX.
/Yoyo
Apr 23, 2021 9:24 AM UTC
@yhan Thanks for the quick reply. Can u pls provide link for the d3 chart and also guide for creating extension?
yhan17-PeridotAnswer
Hi @PM_9712905
/Yoyo
Support
Apr 30, 2021 8:24 PM UTC
Hi @PM_9712905.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
