Datachange event not firing with MQTT
  • July 31, 2021
  • 1158 views
I have a property under a MQTT Thing that is subscribed to a broker topic and is bound to a data change event in a subscription. However, I find that the event is only fired when I manually change the property value versus when it changes using MQTT.
Thanks!
Best answer by PaiChung
Try changing the Property aspect 'Data Change' to 'Always' vs. 'Value'
PaiChung22-Sapphire IAnswer
22-Sapphire I
August 3, 2021
