PaiChungAnswer
22-Sapphire I
Sep 17, 2019 1:23 PM UTC
For the pdf extension we recommend creating a purpose built mashup.
So you would create an additional mashup that has the look of what you want to produce in your pdf
22-Sapphire I
Sep 16, 2019 2:35 PM UTC
There are some extensions in the Marketplace that can publish content to PDF.
You could also use the regular Print function and print to PDF
could also create some download file based on the parameters which then can be printed to pdf.
Sep 17, 2019 6:22 AM UTC
Thanks for your response.
The requirement is to convert to PDF and store it in the repository. The print option printing the entire Mashup which has irrelevant content as well.
And,
Can you suggest any extension which has proper documentation. I gone thru some extensions which don`t even have the ReadMe file.
ex. solr
Thank you,
Janakiraman P
Sep 17, 2019 11:27 AM UTC
Hi @Janakiraman-P ,
Try PDF Extension.
PDF Extension, which is available in marketplace, can convert mashups into pdf format and you could download the same from repository.
With regards
Yedukrishnan
