Apr 13, 2021 12:59 PM UTC
Error installation Thingworx Foundation 9.1
I'm trying to install Foundation 9.1 trial, with no success. I have checked the Java version,it's OK. The installer goes on untill step 3, without problem. I can even see the installer creates the folders for the program, but then I receive a message error, telling that the installation failed, and the application will exit. And all the new folders disappear.
PaiChungAnswer
22-Sapphire I
Apr 15, 2021 5:35 PM UTC
The only other thing that I can think off is that perhaps it has to do with your language setting and if you could temporarily set it to English (US) and see if that works or not.
22-Sapphire I
Apr 13, 2021 2:08 PM UTC
TBH I've never used the installer, but I would check your system path make sure it points to the right version of java (Environment Variables/Path)
The other would be perhaps permissions, run as Administrator?
Apr 13, 2021 2:33 PM UTC
I confirm that Java path is OK, and I run installation as administrator.
Apr 14, 2021 4:43 AM UTC
Hi @ML_8931370
Could you please send me the installation log file, you can capture that before exiting the installer .
File must be present at the directory where your ThingWorx is getting installed.
Also, please share the value which you are setting in your "JAVA_HOME" and "path" system variable
Toolika Dixit
