Error trying to connect ThingWorx to the raspberry pi.
Hi. I joined this community just a few weeks ago because i'm currently working on a project among which basically consist on transfering some kind of information to a clud using a Raspberry pi device.
I'm currently dealing with the Quickstart tutorial, but i'm having next problems while trying to validate that my EMS has been succesfully connected:
[INFO ] 2017-12-20 18:42:56,583 ./wsems: Using config file: /home/pi/microserver/etc/config.json
[FORCE] 2017-12-20 18:42:56,583 ./wsems: Starting up ....
[FORCE] 2017-12-20 18:42:56,584 ./wsems: Initializing EMS ....
[FORCE] 2017-12-20 18:42:56,584 main: Using config file /home/pi/microserver/etc/config.json
[INFO ] 2017-12-20 18:42:56,584 ./wsems: Creating the WsEms proxy.
[INFO ] 2017-12-20 18:42:56,584 ./wsems: Starting HTTP Server.
[INFO ] 2017-12-20 18:42:56,585 ./wsems: Initializing the ThingWorx REST interface.
[FORCE] 2017-12-20 18:42:56,585 httpServer: starting http server port=8080
[DEBUG] 2017-12-20 18:42:56,585 httpServer: http server bound to port=8080.
[DEBUG] 2017-12-20 18:42:56,587 SDK: twWs_Create: Initializing Websocket Client for 10.0.75.1:80//Thingworx/WS
[DEBUG] 2017-12-20 18:42:56,587 SDK: twTlsClient_Create: Initializing TLS Client
[DEBUG] 2017-12-20 18:42:56,587 SDK: twApi_Initialize: Websocket Established after 0 tries
[DEBUG] 2017-12-20 18:42:56,587 SDK: subscribedPropsMgr_Initialize: Initializing subscribed properties manager
[DEBUG] 2017-12-20 18:42:56,587 jsonConfigurator::getJsonEntity: Key cert_chain not found
[DEBUG] 2017-12-20 18:42:56,587 jsonConfigurator::getJsonEntity: Key validation_criteria not found
[DEBUG] 2017-12-20 18:42:56,588 jsonConfigurator::getJsonEntity: Parent file not found
[DEBUG] 2017-12-20 18:42:56,589 SDK: twTunnelManager_Create: Tunnel Manager singleton already exists
[DEBUG] 2017-12-20 18:42:56,588 WsEmsProxy::bindThing: Host specified as 'localhost'. Testing IPV6/IPV4 connectivity
[WARN ] 2017-12-20 18:42:56,599 WsEmsProxy::bindThing: Exception connecting to localhost:8001. Err: Connection refused [localhost:8001]
[WARN ] 2017-12-20 18:42:56,599 WsEmsProxy::bindThing: Changing host from 'localhost' to '127.0.0.1'
[DEBUG] 2017-12-20 18:42:56,600 SDK: added PiThing to boundList
[DEBUG] 2017-12-20 18:42:56,600 SDK: twApi_BindThings: not currently connected, only binding things to api
[DEBUG] 2017-12-20 18:42:56,600 SDK: twMessage_Delete: Deleting BIND Message: 1
[DEBUG] 2017-12-20 18:42:56,600 jsonConfigurator::getJsonEntity: Parent file not found
[INFO ] 2017-12-20 18:42:56,600 wsEmsProxy::initialize: Initialization complete!
[INFO ] 2017-12-20 18:42:56,601 ./wsems: Starting the connection.
10.0.75.1:80-->[DEBUG] 2017-12-20 18:42:56,604 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-12-20 18:42:56,604 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-12-20 18:42:59,749 SDK: Error intializing socket connection. Err = 113
[ERROR] 2017-12-20 18:42:59,749 SDK: twWs_Connect: Error restarting socket. Error 113
[DEBUG] 2017-12-20 18:43:04,749 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-12-20 18:43:04,749 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-12-20 18:43:07,909 SDK: Error intializing socket connection. Err = 113
[ERROR] 2017-12-20 18:43:07,909 SDK: twWs_Connect: Error restarting socket. Error 113
[DEBUG] 2017-12-20 18:43:12,909 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-12-20 18:43:12,909 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-12-20 18:43:16,69 SDK: Error intializing socket connection. Err = 113
[ERROR] 2017-12-20 18:43:16,69 SDK: twWs_Connect: Error restarting socket. Error 113
[DEBUG] 2017-12-20 18:43:21,69 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-12-20 18:43:21,69 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-12-20 18:43:24,229 SDK: Error intializing socket connection. Err = 113
[ERROR] 2017-12-20 18:43:24,229 SDK: twWs_Connect: Error restarting socket. Error 113
[DEBUG] 2017-12-20 18:43:29,229 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-12-20 18:43:29,229 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-12-20 18:43:32,389 SDK: Error intializing socket connection. Err = 113
[ERROR] 2017-12-20 18:43:32,389 SDK: twWs_Connect: Error restarting socket. Error 113
[DEBUG] 2017-12-20 18:43:37,389 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-12-20 18:43:37,389 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-12-20 18:43:40,549 SDK: Error intializing socket connection. Err = 113
[ERROR] 2017-12-20 18:43:40,549 SDK: twWs_Connect: Error restarting socket. Error 113
[DEBUG] 2017-12-20 18:43:45,549 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-12-20 18:43:45,549 SDK: twTlsClient_Connect: Connecting to server
[ERROR] 2017-12-20 18:43:48,709 SDK: Error intializing socket connection. Err = 113
[ERROR] 2017-12-20 18:43:48,709 SDK: twWs_Connect: Error restarting socket. Error 113
[DEBUG] 2017-12-20 18:43:53,709 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2017-12-20 18:43:53,709 SDK: twTlsClient_Connect: Connecting to server
[WARN ] 2017-12-20 18:43:56,609 Main: Unable to connect to server. Trying .booted config file
[ERROR] 2017-12-20 18:43:56,868 SDK: Error intializing socket connection. Err = 113
[ERROR] 2017-12-20 18:43:56,869 SDK: twWs_Connect: Error restarting socket. Error 113
[WARN ] 2017-12-20 18:44:01,868 WsEmsProxy::execute() : Server connection failed. Error Code: 1001
[FORCE] 2017-12-20 18:44:06,679 Main: Shutdown signal received. Restarting ....
[DEBUG] 2017-12-20 18:44:06,680 SDK: twMessage_Send: Not authenticated yet
[ERROR] 2017-12-20 18:44:06,680 SDK: twMessage_Send: Error sending Message with RequestId 2
[ERROR] 2017-12-20 18:44:06,680 SDK: twApi_UnbindThing: Error creating sending Unbind message
[DEBUG] 2017-12-20 18:44:06,680 SDK: twMessage_Delete: Deleting BIND Message: 2
terminate called without an active exception
My jason.file is looking as follows:
"ws_servers": [{
"host": "10.0.75.1",
"port": 80
"http_server": {
"host": "127.0.0.1",
"port": 8080
"appKey": "cb983f51-0072-4945-ab9a-e2856a122c39",
"logger": {
"level": "DEBUG"
"auto_bind": [{
"name": "PiThing",
"gateway": false
"certificates": {
"validate": false,
"allow_self_signed": true
"ws_connection": {
"encryption": "none",
"verbose": true,
"msg_timeout": 1000
Could somebody help me please?, becase I need to go through this step in order to continue with the tutorial.
