Error while deploying thingworx.war in webapp folder manually
Attached a Tomcat log..
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.5.29
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Mar 5 2018 13:11:12 UTC
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.5.29.0
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 7
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 6.1
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: x86
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\Program Files (x86)\Java\jre1.8.0_161
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_161-b12
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5\temp
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5\conf\logging.properties
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dserver -Dd64
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseG1GC
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dfile.encoding=UTF-8
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.library.path=C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5\webapps\Thingworx\WEB-INF\extensions
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: abort
02-Apr-2018 01:17:30.074 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: [C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5\webapps\Thingworx\WEB-INF\extensions]
02-Apr-2018 01:17:30.215 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8015"]
02-Apr-2018 01:17:30.371 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
02-Apr-2018 01:17:30.386 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"]
02-Apr-2018 01:17:30.386 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
02-Apr-2018 01:17:30.386 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 759 ms
02-Apr-2018 01:17:30.418 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
02-Apr-2018 01:17:30.418 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.5.29
02-Apr-2018 01:17:30.449 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive [C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5\webapps\Thingworx.war]
02-Apr-2018 01:17:58.890 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
02-Apr-2018 01:17:59.811 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal One or more Filters failed to start. Full details will be found in the appropriate container log file
02-Apr-2018 01:17:59.811 SEVERE [localhost-startStop-1] org.apache.catalina.core.StandardContext.startInternal Context [/Thingworx] startup failed due to previous errors
02-Apr-2018 01:17:59.935 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive [C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5\webapps\Thingworx.war] has finished in [29,486] ms
02-Apr-2018 01:17:59.935 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5\webapps\docs]
02-Apr-2018 01:17:59.982 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5\webapps\docs] has finished in [47] ms
02-Apr-2018 01:17:59.982 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5\webapps\manager]
02-Apr-2018 01:18:00.013 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5\webapps\manager] has finished in [31] ms
02-Apr-2018 01:18:00.013 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory [C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5\webapps\ROOT]
02-Apr-2018 01:18:00.045 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory [C:\Program Files (x86)\Apache Software Foundation\Tomcat 8.5\webapps\ROOT] has finished in [32] ms
02-Apr-2018 01:18:00.045 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8015"]
02-Apr-2018 01:18:00.060 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-8009"]
02-Apr-2018 01:18:00.060 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 29666 ms
Also i have attached server.xml. I have done Replace HTTP/1.1 with protocol="org.apache.coyote.http11.Http11NioProtocol".
can you please help. im not able to install thingworx in my system.
