Mar 1, 2021 3:31 PM UTC
Give RunTime Permission to all Entities of a Project
Hello!
I'm trying to give RunTime permission to a certain User Group for all the entities of a project, so I don't want to give to ALL the entities, just the specific ones from the project. I've tried using the AddCollectionRunTimePermission function but the permissions didn't change. Is there another way or function?
Thank you so much in advance.
Mar 4, 2021 2:59 PM UTC
You have to assign group to the menu on the menu definition tab
Mar 1, 2021 6:13 PM UTC
you can use: Resources["EntityServices"].SetEntityPermission(params); . This takes projectName as an input, using this you can set run time permission on all of your entites which are associated with a particular project.
Mar 3, 2021 3:25 PM UTC
Hello! thank you so much for your suggestion. But unfortunately, the menu entities in the mashups still won't work, do I need to give runtime permission to some Resource entities or something like that?
