Google Map Widget Tutorial?
  • September 16, 2017
  • 2 replies
  • 4211 views
hi all,
i am newbie to thingworx, i have several problem using google maps widget. is there any tutorial step by step using the google map widget.
i have problem to show marker on the location.
i have created infotable which has location and the location has default value(from datashape) but when i bind the info table to gmpas, i can choose location field as location, but in runtime, there is no marker, even though show marker set to true....
i dont know if i have created wrong infotable..
if there is link step by step how to use google maps, please let me know...
thanks
Hi, there's some Information available in the ThingWorx Help Center Topic Google Widgets. Plus there are some additional tutorial videos available on Google Widget here ThingWorx Video Tutorials -> see section ThingWorx Widgets
Hope this would help. Feel free to share your questions if you still run into issues.
20-Turquoise
September 18, 2017
Please refer to the helpcenter PTC
If you are still having problems with implementing after reviewing the documentation, please let me know and I will put up an example for you.
