Apr 17, 2025 11:47 AM UTC
How to clear/remove array in sessionStorage
I am storing array in sessionstorage. I'm able to update the array using
sessionStorage.setItem(Op_withoutSpaces + "_" + i, array);
but i couldn't remove or clear the array in sessionstorage using below code.
sessionStorage.clear(Op_withoutSpaces + "_" + i);
sessionStorage.RemoveItem(Op_withoutSpaces + "_" + i);
Let me know what is wrong in this.
TonyZhangAnswer
Support
May 19, 2025 4:21 AM UTC
Hi @AP_10343008,
First of all, TW.sessionStorage.clear() function doesn't accept any arguments, this function will clear ALL items in sessionStorage.
Refer to MDN document.
So you are not supposed to pass anything in the parenthesis like below.
TW.sessionStorage.clear(Op_withoutSpaces + "_" + i);
Secondly, can you try removing other code and passing hard-coded key name to TW.sessionStorage.RemoveItem("key") instead of parameter for testing purpose?
I tested both TW.sessionStorage.clear and TW.sessionStorage.RemoveItem("key") in expression and both work just fine.
Apr 17, 2025 1:01 PM UTC
Hi @AP_10343008  can you use it in the format below?
TW.sessionStorage.removeItem()
Apr 21, 2025 3:58 PM UTC
Still it is not working. I uploaded the code which written in the expression of mashup. Kindly take a look.
Apr 24, 2025 9:08 AM UTC
Anyone knows why remove item is not working in session ? Please find the code i have attached.
