How to copy files from EMS to TWX repo
sabharees
I connected ems to twx and followed ems connectivity steps from connect EMS to Thingworx tutorial
I am able to see the list of files from ems.
I tried copying, moving files from ems to twx repo but not able to complete the process.
Getting error in twx composer : Error executing service readFiles. Message :: Wrapped com.thingworx.common.exceptions.GenericHTTPException - See Script Error Log for more details.
Getting error in ems: FileTransferService::execute: EdgeThing MoveFile unsuccessful. Return code : 0xA0
PaiChung
22-Sapphire I
(To:sabharees)
The mashup basically just helps with the visual and the 'paths' but you can do that with services as well, again use the 'FileTransfer Subsystem' services to do it.
4 REPLIES 4
PaiChung
22-Sapphire I
(To:sabharees)
It's been a very long time since I've done this, but that looks like you are copying a file from one folder to another from the perspective of the EdgeThing vs. moving it from the EMS repository to your platform FileRepository.
I recommend you create a mashup with on the one side your Edge and the other side your Repository and use the 'FileTransfer Subsystem' services to copy/move the file.
sabharees
(To:PaiChung)
Thanks Pai for the replies,
But, I would like to proceed via services without having any mashups is that is possible or any workaround will able to allow me to perform this activity ?
PaiChung
22-Sapphire I
(To:sabharees)
slangley
23-Emerald II
(To:sabharees)
Hi @sabharees.
If either of the previous responses helped you to find a solution, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
