Aug 10, 2021 2:04 PM UTC
How to create get API in Thingworx with getting all data json format ?
           I want to create get API in Thingworx from service with converting data table format into json format? for this I create one query for getting all data and use tojson() snippets ..... set output as json base type, but I'm getting output in info table. I also used getjson() snippets and getting blank headers output please refer below attachments and suggest :
 How to create get API in Thingworx with getting all data in Json format ?
Thanks in Advance
tojson()snippets output:
getjson()snippets output:
PaiChungAnswer
22-Sapphire I
Aug 13, 2021 12:44 PM UTC
If you take your content as an infotable and assign it to a property
then when you do a get with 'accept-type' as application/json you should get that infotable as a json.
22-Sapphire I
Aug 11, 2021 2:01 PM UTC
A GET would only work if you are reading some in memory information.
So if you set the value on a Property you should be able to retrieve that with a GET
RM1214-AlexandriteAuthor
Aug 13, 2021 10:14 AM UTC
Thanks for giving response, Yes I want to retrieve data from PostgreSQL Database and want to convert table format data into JSON format .for this ,I tried below query in PostgreSQL when when I set output as JSON base type it gave me no result but when I set output as Infotable base type gave me table format JSON data and I want in proper JSON format Data so please refer below attachment and suggest :
How do I covert table format data into proper JSON format data ??
select row_to_json("tbl_machine") as json from "tbl_machine"
Output Getting :
Postman Output :
Expected Output :
PaiChung22-Sapphire IAnswer
22-Sapphire I
