Apr 29, 2020 7:42 AM UTC
How to get by default selected menu in a dynamic menu list.
Hi, Thank you for your interest in helping me.
My codes are
var row = new Object();
row.linkDestination = mainMash;
row.parentMenuId = "Menu";
row.menuId = "Menu_0";
row.isDefault = true;                      // I make it true to get default selection but it's not working.
row.imageURL = "";
row.linkTarget = "Self";
row.description = "";
row.linkType = "Mashup";
row.title = "MAP";
result.AddRow(row);
Is it correct. Please help me with that. Thank you!
Support
Apr 29, 2020 7:21 PM UTC
Hi @menayat.
This course on the Developer portal may be helpful:
Customizable and Responsive UI
--Sharon
Support
May 7, 2020 7:49 PM UTC
Hi @menayat.
If the previous response helped you to find a solution, please mark it as the Accepted Solution for the benefit of others on the community.
--Sharon
menayat1-VisitorAuthor
May 7, 2020 9:47 PM UTC
No, still I didn't get any solution.
And I think thingworx has drawbacks here with this dynamic menu.
If a user is creating a dynamic menu and passing the value from service and make the entry
isDefault = true;
and in another hand, if the user will create a menu static and tick on default then is selecting when a master is loading.
then thingworx should take the menu as default selected menu but it's not taking.
To Thingworx team please make it correct.
