May 21, 2019 10:59 AM UTC
How to get certain number of rows from Infotable
Is there a way by which we can get certain limited number of rows from infotable, without writing any custom service/code.
For example I have 10 rows in my infotable, and I want first 5 rows, is there any service available which I can use to get that?
Thanks in advance
Regards
Aditya Mittal
zyuan1Answer
May 22, 2019 3:03 AM UTC
Hi, you can get a limit number of rows by controlling the Maxitem in the infotable query services, or add a snippet to the existing infotable result:
var params = {
maxItems: undefined /* NUMBER */,
t: undefined /* INFOTABLE */
// result: INFOTABLE
var result = Resources["InfoTableFunctions"].TopN(params);
20-Turquoise
May 21, 2019 2:49 PM UTC
You could probably set your query to max rows 5. Other than that, we don't have any specific out of the box service available for this use case.
amittal11-VisitorAuthor
May 22, 2019 2:47 AM UTC
Thanks for your reply. I would like to know how to write a query to get the maximum number of rows from a infotable. Even using a query will work for me, because in any case I am using a query on my infotable, so I can add one more parameter for Max rows, that is fine for me. I usually refer following link whenever I have to write a query:
https://support.ptc.com/cs/help/thingworx_hc/thingworx_7.0_hc/index.jspx?id=QueryParameterforQueryServices&action=show
If there is some other reference, please share, it would be helpful.
Many thanks
Regards
Aditya
zyuan15-Regular MemberAnswer
var params = {
