How to query form infotable using query function?
Could anyone help us to query from info table based on condition?
We found query info table function but need to know query syntax please send us sample syntax
Example:
var params = {
  t: result1 /* INFOTABLE */,
  query: what to write here and how  /* QUERY */
// result: INFOTABLE
var result = Resources["InfoTableFunctions"].Query(params);
We want to check where condition like where name ='anil' and id=1
Anil Kesana
MichailAnswer
var query =
  "filters": {
  "type": "OR",
  "filters": [
  "type": "EQ",
  "fieldName": "Duration",
  "value": "12"
  "type": "EQ",
  "value": "20"
look for "query parameter" in the documentation.
var query =
  "filters": {
  "type": "GT, LT, GE, LE, NE, EQ, LIKE, NOTLIKE",
  "value": "12"
var params = {
  query: query  /* QUERY */
akesana1-VisitorAuthor
Hi Mnudel,
Thanks for your quick response , but I want to check multiple conditions not single value.
Could you explain that ?
var query =
  "filters": {
  "type": "EQ",
  "value": "12" and/or "20"   //like this I want to check will it possible please send syntax for the same
var params = {
Anil Kesana
Michail1-VisitorAnswer
var query =
  "filters": {
  "type": "OR",
  "filters": [
  "type": "EQ",
  "value": "12"
  "type": "EQ",
  "value": "20"
