Oct 24, 2017 7:59 AM UTC
How to read csv/excel file and get columns data
Hello, I would like to read CSV file in the thingworx platform, I execute these java code into a service:
var params = {
    path: "TF.csv" /* STRING */,
    columnMappings: undefined /* STRING */,
    hasHeader: undefined /* BOOLEAN */,
    longitudeField: undefined /* NUMBER */,
    dateFormat: undefined /* STRING */,
    fileRepository: "SystemRepository",
    latitudeField: undefined /* NUMBER */,
    fieldDelimiter: "," /* STRING */,
    stringDelimiter: "," /* STRING */,
    dataShape: "TFData" /* DATASHAPENAME */
var result = Resources["CSVParserFunctions"].ReadCSVFile(params);
When I test this code lines, I got this error:
Wrapped java.lang.Exception: Unable To Convert From java.lang.String to NUMBER Cause: Unable To Convert From java.lang.String to NUMBER
Any help please !
Oct 24, 2017 8:37 AM UTC
Ta least you need columnMappings to be set ( separated by ";" ) and I don't think it's logic to set fieldDelimiter = stringDelimiter.
Oct 24, 2017 8:51 AM UTC
Thank you Mr.Carles,
I got this error now after deleting the stringDelimiter:
Wrapped java.lang.IndexOutOfBoundsException: Index: 1, Size: 1 Cause: Index: 1, Size: 1
Did you set column Mappings, do you have a String Delimiter( it's mandatory)
Oct 24, 2017 9:02 AM UTC
How can I set a column Mappings ?
In my CSV file I have a delimiter and it's ','
Oct 24, 2017 1:03 PM UTC
On moment I saw on one of your previous posts:
columnMappings: 'cell_easting,cell_northing'
should be:
columnMappings: 'cell_easting;cell_northing'
Oct 24, 2017 1:10 PM UTC
Yes it is, I change that
var params = {
    path: "TF_Jun.csv" /* STRING */,
    columnMappings:'cell_easting;cell_northing',
    hasHeader: true /* BOOLEAN */,
    stringDelimiter: "\"" /* STRING */,
    dataShape: "TFUrbanizationData" /* DATASHAPENAME */
But the prob I got this error:
Oct 24, 2017 1:12 PM UTC
If you aren't using latest csv file importer extension, add a new line on the bottom of the file.
