pshashipreetham
Dec 25, 2021 9:22 PM UTC
Line Chart Padding Issue
Placed a Line Chart on the Mashup, as soon as Chart Plotted, the chart is not getting placed properly on the dashboard.
May be this is due to the Padding issue. The Line chart on the dashboard is something like this:
 How Can Padding properly set for the Line Chart.
@paic @slangley @c_lowy @VladimirN
Shashi
pshashipreetham
Jan 8, 2022 8:23 AM UTC
The issue is solved by the CSS provided by @c_lowy .
ptcs-chart-line::part(chart-layout) {
padding: 0;
If there are 2 or more DataSources given to the Line chart,
1. Enable the Multiple Data source Visualization option in widget properties, and
2. Connect to the 2 or more Data Sources to chart widget again.
3. Select the X Axis as TimeStamp(in my case)
Shashi
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
Dec 27, 2021 5:44 AM UTC
Hi @pshashipreetham ,
Kindly check the below attached article:
https://www.ptc.com/en/support/article/CS343992?posno=1&q=line%20chart%20padding&source=search
Revert back in case of further challenges.
Regards
Bhawna
pshashipreetham
Dec 27, 2021 7:19 AM UTC
Hi @bchaudhary_448008 ,
tried the article, didn't help. The Picture in the issue posted is after trying out the article you have shared.
Shashi.
Dec 29, 2021 2:06 PM UTC
@pshashipreetham
Have you provided values for the properties "XAxisMaxmumValues", "XAxisMinimumValues", "YAxisMaximumValues" and "YAxisMinimumValues". These properties can be bound to services if the X Axis values change based on other issues.
Hope this helps.
Dec 29, 2021 5:48 AM UTC
make the container fixed height
pshashipreetham
Dec 30, 2021 12:14 PM UTC
Hey Hi @GuruPrasad1 ,
Didn't get you, can you show a example ?
Shashi.
Dec 30, 2021 12:30 PM UTC
Hi Shashi,
Usually this happens when the container in which your are placing the chart is responsive, if you instead choose a fixed length and give a value say 500px this would appear better. This settings you can find in the layout tab am attching
Regards
Guruprasad S
pshashipreetham
pshashipreetham19-TanzaniteAuthorAnswer
padding: 0;
Shashi
