No 'Access-Control-Allow-Origin' - Thingworx 8.4/8.5
  • June 15, 2019
  • 8036 views
Hi @unknown ,
I am try get data from thingworx with HTTP POST request (JavaScript/HTML). But i am get an error like below,
Access to XMLHttpRequest at 'http://localhost:8080/Thingworx/Things?appKey=c0f49d05-d5a2-4d73-857e-4bc6ef7f89bf' from origin 'null' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource.
I have updated "web.xml" file also enabled "Allow Request Method Switch" and "Allow Application key as URL Parameter". Still i am facing the same issue. Can i have a solution.?
Thanks.
Anyone have answer for this? @tmisner
Hello Sathishkumar,
Thank you for reaching out on the ThingWorx Developer Community.
Would it be possible to share the service code or further details on what data you are attempting to retrieve and more specifically how you are retrieving it?
I would also like to look at the web.xml file if you could provide it.
You are welcome to share these details in a private message if you would prefer.
Additionally, please investigate the details mentioned in CS229450 which covers the proper configuration of CORS on Tomcat with ThingWorx.
Tyler Misner
ThingWorx Technical Support Engineer
Hi Tyler.
Thanks for your response. But I am getting same response like 'No Access-Control-Allow-Origin'. I have updated web.xml and platform subsystem attributes.
Any other possible errors??
