Pass a query parameter from URL to master
  • April 23, 2024
  • 1351 views
How to pass a query parameter from URL to Thingworx Master? I know we can set a mashup parameter, but is there a possibility to send this mashup parameter to master before the master loads?
Also, is there a way to load the master after the service in contained mashup has been completed?
Su
Hi @suraj_visvesh
You can pass default value for Mashup Parameter in URL
For example : If you have a Mashup Parameter named "thingName" and if you want to load/set default value for it.
You can set value while accessing URL - <<THINGWORX>>/Mashups/TestMashup?thingName=TestThing
/VR
Hi @Velkumar,
Yes I know we can get a parameter for a mashup, but how do I pass this to master of the mashup? I have a service in master which would require a parameter from the URL.
Suraj
Hi @suraj_visvesh
You can create a session parameter and pass value from child mashup to session. In Master Mashup, you can retrieve value from Session parameters
More about Session Parameters - Session Parameters (ptc.com)
/VR
