Jun 14, 2017 3:53 PM UTC
Problem to configure Analytics Server in Analytics Builder
Following the steps of the Analytics Builder Quickstart, I reach the point where the Analytic Server must be identified.
I set the IP for the local Analytic Server and I set "neuronuser" as Application Id. When I execute "Verify Configuration", the next message appears on the top of the screen:
Error invoking service: Invalid Analytics Server Version (ValidateMLServerVersion#5)
I have installed Analytics Server 7.4, and I'm using Thingworx 7.4.
Could anyone give me any clue about this issue?
Thank you very much
cmorfinAnswer
Jun 15, 2017 8:17 AM UTC
Hi
you mentioned using ThingWorx Analytics server 7.4 with ThingWorx 7.4.
Could you also specify the version of the ThingWorx Analytics extension you have, as seen in Import/Export > Manage ?
Also for the endpoint Host, you should have <host>:<port> , you seem to indicate to have entered only the ip address.
You can check this video at time 25 sec: Video Link : 1676, to compare the Settings.
The /analytics mentioned by Mohit is something that needs to be added if using ThingWorx analytics 8.0 but that does not seem to be your case.
Christophe
Jun 15, 2017 6:06 AM UTC
DAVID ALGUACIL​:
Could you please confirm if you analytic server is up and running as the error message you received comes when server is down.
Try updating application id as analytics.
Please ensure ​Endpoint host contains <IP>:<PORT>/analytics
cmorfin19-TanzaniteAnswer
Hi
Christophe
dalguacil1-VisitorAuthor
Jun 15, 2017 10:28 AM UTC
Thank you for your answers.
The problem is that services are not started in the VM. This morning I have repeat the procedure and everything seems to be OK. However, if I run the command "service --status-all", there is no services running. I expected to see Zookeeper, PostgreSQL Server, GridWorker and Tomcat services (as it specified in Troubleshooting Steps for ThingWorx Analytics: Restarting Services Manually, or full Graceful Restart of Application
In fact, when I try to access to the Analytics Server from any web browser, it is not accessible.If I run a ping command to the VM, there is good reply.
Jun 15, 2017 10:58 AM UTC
Hi David
Can you post the output of :
- ps -ef | grep postgres:
- ls -l /var/lib/pgsql/9.4/data
and upload the Tomcat log file under /usr/share/tomcat/logs
Thank you
Kind regards
Christophe
Jun 15, 2017 11:24 AM UTC
Finally I could solve the problem.
When I installed the Analytic Server, I changed the Network configuration to be accessible in the local network. For some reason, it induced a problem during the virtual machine start up and the services were not started.
Now, I have the virtual machine network adapted configured as Bridge with a IP valid for the local network. With this, I have access to the Analytics Server from any computer in the local network.
I have restarted the tutorial and I have configured the Thingworx Analytics Server as both, Mohit and Christophe, told me, using the IP:PORT.
Now everything is working.
Thank you very much
Jul 6, 2017 12:56 PM UTC
Hi David
Can you please help me with same issue? I have installed Thingworx Anlytics 8 on my laptop(since we dont have compatibility with server for TWA 😎
and even my url for TWA 8 server is not accessible from other systems. So i am also getting error which you mentioned.
Can you please help how you fixed "the virtual machine network adapted configured as Bridge with a IP valid for the local network".
Mohit Goel​
Ravi
Jul 7, 2017 8:48 AM UTC
Hi Ravindra
I would recommend you open a new discussion detailing your specific configuration.
A connection error can come from many different reasons, so  is likely to be different form what was discussed here.
In the new discussion, please provide:
- the error message you get and where/when you get it
- the version of ThingWorx and ThingWorx Analytics
- log files:
     - <ThingworxStorage>/Logs/ApplicationLog.log
     - <ThingWorx Tomcat>/logs folder
     - <ThingWorx Analytics Tomcat>/logs folder
Christophe
