RadioButton SelectedValue not set to default value at Mashup load
  • March 14, 2017
  • 2967 views
I have a RadioButton with two states and I have set one of the states as default. When I start the Mashup the correct button is selected (blue) so I assume it's working.
However, the SelectedValue is set to undefined at startup instead of the default value. I have to manually click on the RadioButton to get some sensible value to the SelectedValue. Surely, it should be set to default by default? What is the use of the default value if it's not reflected in the SelectedValue?
Of course I can make a service that sets the value at startup but I should not need to do it. Is this a bug? Did I do something wrong?
-Risto
PS:
I'm using version 7.2.5-b56.
Hi Risto Vaaraniemi​,
Could you please open a TS case with PTC to report this Bug. I am also able to reproduce it.
Ankit Gupta
Sure. Just let me know what to do.
Thanks for confirming the case.
-Risto
Hi, Please open a TS case with PTC to report this Bug.
