Apr 24, 2018 11:36 AM UTC
[Request] Time Series DataSet.
Hi everyone,
do anyone of you have a time series data set that i can use to try time series prediction using thing predictor ?
Apr 24, 2018 12:25 PM UTC
Hi
You can find a sample time series dataset to use with Analytics at https://www.ptc.com/en/support/article?n=CS258345
However, for ThingPredictor, please be mindful of the limitation noted in Help Center: https://support.ptc.com/help/thingworx_hc/thingworx_analytics_8/#page/thingworx_analytics_8%2Fthingpredictor%2Fthingpredictor-limitations.html%23
"In this release, the ThingPredictor client scoring through Analytics Manager does not support time series models"
Release 8.3 should bring better support for time series with ThingPredictor
Apr 24, 2018 5:40 PM UTC
Hi Christophe,
Thank you for the provided data set , but the question is what is the goal variable in that  data set ?
Apr 25, 2018 12:52 PM UTC
Hi
The dataset is a sample dummy time series dataset.
It pretends to predict the watervolume based on some current and voltage values.
It is not about failure prediction.
I do not have dataset for time to failure
Christophe
